What does this wire do?
Old Feb 28, 2010 | 07:14 PM
csam's Avatar
csam
Default What does this wire do?
I was changing oil today and got zapped by this wire. I removed the 2' lead that was attached as it was burned through the insulation. The unattached end had a two pronged plug, and was left dangling by someone who worked on the car recently.
Any ideas on what that would plug into on a '92 Dakota 3.9l 2wd? I can't figure anything out from any wiring diagrams, but that is like reading Chinese. My engine temp gauge is not working at all, so I am hoping that is it, at least that is my best guess.
Old Feb 28, 2010 | 07:55 PM
dodgerules86's Avatar
dodgerules86
No idea, but that doesn't look like a stock Dodge connector to me.
Old Feb 28, 2010 | 08:33 PM
95_318SLT's Avatar
95_318SLT
Looks to me like the harness for the overhead light thats under the hood. The only reason I know that is cause I unplug it all the time when I'm working on my truck during the day.
Old Feb 28, 2010 | 08:54 PM
Az93DKota's Avatar
Az93DKota
I agree
Old Feb 28, 2010 | 09:49 PM
csam's Avatar
csam
yes, excellent, great! I will investigate further. I was really stumped too. the lead was draped down over he engine and had burned a bit.
Thanks
Old Mar 1, 2010 | 01:57 PM
Az93DKota's Avatar
Az93DKota
Thanks
Fix the connector. And put a multimeter in the plug and open and close the hood. The power reading should cut off.
Old Mar 1, 2010 | 02:48 PM
dodgerules86
Not so. The hot wire to the under hood light is hot at all times.
A mercury switch, in the ground circuit, it what "trips" the light.
From the service manual:
A mercury switch, in series after the lamp, connects the lamp to ground on circuit Z1. When the hood is raised, mercury inside the switch moves to a position where it connects circuit M1 to ground circuit Z1, illuminating the lamp
