Whats wrong :(
Old Mar 15, 2010 | 11:56 PM
blackandsilver95's Avatar
blackandsilver95
Default Whats wrong :(
i have a 95 dak 3.9 2wd and i was dribing the other day and i about ran out of gas but i made it and then got in it the next morning to go put gas in it and it barely wanted to start so today i drove it and it died down the road and would not start again so i towed it to a friends house took the bed off and took the fuel pump<====(#5 in 2 yrs)out and replaced it with a new and now it wont start again the pump doesnt turn on and it dont have spark i checked all fuses and relays and nothing and when the truck would run the volts gauge is on 18v thanks for the help
Old Mar 16, 2010 | 12:31 AM
dbilik's Avatar
dbilik
The pump is getting power? Can you get the pump to run by hooking it up directly to power or no?
I would check your grounds and the splice. Are you sure the original pump was bad?
Old Mar 16, 2010 | 03:38 PM
blackandsilver95
i got it fixed today it was the "SPLICE"
Old Mar 16, 2010 | 03:45 PM
dbilik's Avatar
dbilik
Good to hear. Maybe if you give the fuel pump a bath in fabric softener you can get the gasoline smell off enough to return it.
Old Mar 16, 2010 | 05:51 PM
blackandsilver95
na ill keep it my warrenty was up on th 31st so now i got a whole nother yaer with a warrenty on it
