Torsion Bars!!
Old Mar 16, 2010 | 10:48 PM
will4557's Avatar
will4557
Default Torsion Bars!!
What is the process for removing factory torsion keys and replacing them with reindexed keys? Just lift the truck and unbolt them or is there another trick that I need to know? Just wanting to know so I will have everything ready when I get the other keys. Thanks for the help in advance!!
Old Mar 16, 2010 | 11:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it pretty much is lift unbolt remove and replace and tighten it up. At the end of the torsion bar adjuster bolt be carefully the bar may unload and could be dangerous. You can use a Big C-Clamp to help hold it on. For me I didn't need to do that though. Plenty of threads left once the bar was completely loose.
When installing the bolt on the Re-indexed keys the C-Clamp may help.
Old Mar 17, 2010 | 06:20 AM
will4557's Avatar
will4557
ok thanks man for the info. I will be glad to get them changed out and get my truck up in the air a little more.
Old Mar 17, 2010 | 10:40 AM
Bump's Avatar
Bump
Whats the chance that, like a spring, the torsion bars can get "saked out" or "lazy" over time? would a new bar have better "torsion?"
Felipe noted that he had plenty of threads left when the bar went loose, is that because your bar could be "worn" and not returning to its origional (designed) form?
Old Mar 17, 2010 | 12:16 PM
dbilik's Avatar
dbilik
I believe they are designed and set at the factory with the idea in mind that they will settle over time. I think the FSM refers to it somewhere.
Old Mar 17, 2010 | 01:04 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya I'm sure they get worn through out the years and settle down. Think of leaf springs. They settle down and become flat or concave.
That is why the bars come with adjuster bolts, so you can adjust it back to stock hight.
