dakota not starting
Old Mar 22, 2010 | 07:09 PM
put it to the floor's Avatar
put it to the floor
Exclamation dakota not starting
i have a 1993 dakota with the 5.2 ... i was driving down the road when it decided to die then it didnt want to start back up... i checked the fuel pressure fitting on the fuel rail and there wasnt any pressure... so im thinking the fuel pump went
.. i have a 1992 dakota parts truck with a 3.9... will the 3.9 fuel pump be enough for the 5.2
any help would be greatly appreciated....thanks
Old Mar 22, 2010 | 09:06 PM
95_318SLT's Avatar
95_318SLT
Make sure the ASD and Fuel Pump relays are getting power. It is a common problem on these trucks for the power splice that powers those two relays to corrode.
Old Mar 22, 2010 | 10:58 PM
89 d150's Avatar
89 d150
I agree, save time and $$. Strip the housing off of the harness to the ASD and fuel pump relays on the driver's side of the engine compartment. You'll probably find that the power splice is corroded. Check the FAQ section for more detail.
Old Mar 23, 2010 | 12:21 AM
dbilik's Avatar
dbilik
Yep, I made the same mistake and swapped the fuel pump years ago, turned out to just be the splice. I still feel stupid.
Old Apr 2, 2010 | 07:22 AM
cole098's Avatar
cole098
I have the same issue, well I think.. But I checked the faq section search and there is nothing on the fuel pump relay or the ASD showing up in the search.
Can anyone tell me what a ASD is ? I know you guys said its on the driver side of the engine but I dont know exactly where to look for the wire.
Joe
Old Apr 2, 2010 | 12:42 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Joe
You have to look in the FAQ inside this 1st Generation Dakota section. A few posts above this one. It has a green arrow on the left side pointing to it.
Old Apr 2, 2010 | 01:52 PM
95_318SLT's Avatar
95_318SLT
Joe
Truck will not start- A common problem in the trucks, primarily ones made between 1993 Through 1995, was failure (corrosion) of the splice that feeds battery power to the automatic shutdown (ASD) and fuel pump relays. If these relays do not get battery power, your truck will not be able to start. This could also cause intermittent problems, or could possibly "kill" the truck when driving down the road. The splice is located underneath the Power Distribution Center (PDC), which is the black box located behind the battery. To Troubleshoot
https://dodgeforum.com/forum/1st-gen...ce-manual.html
