dakota problem
Old Mar 30, 2010 | 10:31 PM
dakotaredneck's Avatar
dakotaredneck
Default dakota problem
ok guys ive got a problem i was driving down the road the other day and my dakota jus stoped moving we came to a rolling stop jerking will doing so i got out and my left axel has apeard to of sliped out and the right side is locked up i removed the diffrental cover and the two visable gears are fine and the keeper key is broken off and fallen inside the differital by the why its a 1992 4x4 with 3.55 gears any help would be apprictiated and i was wondering if it could be the spider gears
Old Mar 31, 2010 | 12:09 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It could be anything. Since we can't see it we don't know. But the shaft lock bolt brakes and the shaft falls. Then the C-Clip can fall off.
Old Mar 31, 2010 | 12:24 AM
95_318SLT's Avatar
95_318SLT
+1... we need pictures.
Full floating axles for the win! I'd have to shear off 8 bolts before my new rear axle lost an axle shaft... and even then the wheel is still on the hub, so it wouldn't go anywhere. :P
