hard shift from stop
Old Apr 9, 2010 | 05:14 PM
duburban's Avatar
duburban
Default hard shift from stop
I'm getting hard shifts into first and other gears at a dead stop. How do i check master and slave cylinders asides from looking for leaks?
also i can't find Mopar 75W-90, API Grade GL-5 at parts stores and dealer says they need to order it. Whats something generic that i can find anywhere?
Old Apr 9, 2010 | 05:20 PM
dodgerules86's Avatar
dodgerules86
You can use most any 75W-90 gear lube, since most will be GL-5.
For instance, Mobil 1 Synthetic 75W-90 http://www.mobiloil.com/USA-English/..._75W-90LS.aspx
Old Apr 9, 2010 | 06:37 PM
duburban's Avatar
duburban
thanks, really appreciate it. what do you guys think about hard shift to 1st from stop? I haven't found a good test yet.
Old Apr 9, 2010 | 06:50 PM
Jsny1010's Avatar
Jsny1010
what kind of hard shift? does it goto 2/3/4?
Old Apr 10, 2010 | 07:24 AM
duburban's Avatar
duburban
replaced the tranny fluid tonight. didn't help much, but it was low. also the clutch spin down test, putting it in reverse, grinds. so i guess its my pressure plate and clutch. any other ideas?
hard shifts like hard to put it into 1st gear from nuetral at a stop light.
i'm really considering doing this fix. what seals should i have on hand.
planning on:
clutch
pressure plate
pilot bearing
throw out bearing
am i missing anything?
Old Apr 10, 2010 | 08:55 AM
grswat's Avatar
grswat
Aren't we sposed to use syncromesh in the manual transmissions?
Old Apr 11, 2010 | 02:18 PM
duburban's Avatar
duburban
Haynes says 75w90
how long does it take you guys to replace a clutch? i'll triple it for my time estimate.
