useful LA/magnum info
Interesting stuff. I always thought the heads on the 360 where different than the 318. I also thought the 360 RT had different heads, but that would have been after 1997. Since the description only goes to 1997 I guess that still might be the case. Does anyone know for sure what the difference is between the 360RT and a regular 360? I’ve read that the RT had a different cam and heads. I’ve also read that the cam’s and heads are the same and the only difference is in the PCM.
It is interesting that the amount of weight on the converter changed in 1993 with the magnum design. It seems that there is not that much that will retro from the LA to magnum engine.
