master cylinder question
Well I've been gone for a bit but I'm back, now I had oil in my brake fluid so I had to replace anything with rubber in the brake system. Now when my mechanic changed out the master, the first new one was no good, there was nothing at the front brakes. The second one worked for a couple days but then I changed the calipers and the second master went. The third one the brakes would stick. Have any of you guys encountered this with the master on these things? We ended up grabbing the best looking junkyard master and once that one got re-worked in, its worked better than any of those new ones combined...
I bench bled all the masters before they went in. They all turned out defective. What brand do you use?
Did you bleed the brakes too? All 4 wheels, starting from the furthest and work to the closest?
After a few years of Autozone junk I stepped up to Napa. We will see if it lasts better.
No you don't need the engine to be running. But it does help with the power assist.
