88 dakota blown head gasket
Old May 9, 2005 | 07:36 AM
cgates's Avatar
cgates
Default 88 dakota blown head gasket
Hey guys,
was looking for some info and stumbled upon this site....
a friend of mine and I have been working on changing the head gaskets on his 88 dakota. Took the heads off and had them gone over at the shop to make sure they were ok to put back on.
Got everything put back together and started it up. There is now a tapping sound coming from the pass side head and white smoke is coming out of the tailpipe. There was still coolant in the oil and we have drained/replaced the oil twice now.
the side the tapping sound is coming from is the opposite side of the blown head gasket if that makes any difference.
any thoughts/suggestions would be greatly appreciated
Old May 10, 2005 | 03:06 AM
JDakota92's Avatar
JDakota92
Default RE: 88 dakota blown head gasket
Did you do both sides? I assume you did. It sounds like you got a bad gasket, or the head is cracked.
