oil problem fixed
Old May 5, 2010 | 08:18 PM
Big_Phil's Avatar
Big_Phil
Default oil problem fixed
well i had low oil pressure so i replaced the pump. after doing that i sstill had low oil pressure. turns out it was just the oil pressure switch. i almost kicked myself when i found that out. always check the switch first.
Old May 6, 2010 | 01:40 AM
Auron's Avatar
Auron
mine falters evey now and then how did you get yours off
Old May 6, 2010 | 01:43 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Nice! Can't forget to check the easy stuff first. But at least you have a new pump!
Old May 6, 2010 | 11:32 AM
lumix02's Avatar
lumix02
Default help
iv changed the pump and the oil switch still pressure drops at idle
Old May 6, 2010 | 12:15 PM
Az93DKota's Avatar
Az93DKota
PCV maybe??
Old May 6, 2010 | 02:14 PM
lumix02's Avatar
lumix02
Default thanks
thanks mate ill check that tomorow
Old May 6, 2010 | 08:47 PM
Big_Phil's Avatar
Big_Phil
the pump or switch?
