4wd to 2wd!? (i kno...)
Old May 12, 2010 | 12:48 AM
kikazzdakota's Avatar
kikazzdakota
Default 4wd to 2wd!? (i kno...)
ok i got a transfer case that is toast last winter toasted it anyway its inside of my pride and joy and daily driver i waz wondering if u take out the transfer case and get a 2wd drive shaft will it work?? i wanna be able to drive my truck during the summer
Old May 12, 2010 | 12:56 AM
95_318SLT's Avatar
95_318SLT
No, it would not. You would need a 2wd transmission with a 4x4 transmission mount bolted to it and a new driveshaft.
Whats wrong with the transfer case? Is it really so blown up that you can't open it up, take the chain out, and put it back together?
Old May 12, 2010 | 01:10 AM
kikazzdakota
just never tryed i had an exploded view and lost it and i wanted to have it rebuilt professionally cause im just a shadetree mechanic....i dont kno if i could =) is there an exploded view of the transfer case in the faqs?
Old May 12, 2010 | 01:20 AM
95_318SLT's Avatar
95_318SLT
The '95 FSM has a very detailed description of how to tear down and rebuild the transfer case!!
Here is a write up I did about how to change the input shaft in a transfer case... not exactly what you're looking to do, but it might give you an idea what you're up against. Honestly, it's not hard to do... it's nowhere near as complex as a transmission!
Originally Posted by 95_318SLT
So here is the procedure on how to swap the input shafts. The pictures are of the 231 coming apart, the 242 has slightly different internals, but the same procedure works...
1) Remove the tail shaft housing. There are 3 bolts holding it on, and then hit it with a rubber mallet until it breaks loose.
2) Next, to get the rear bearing retainer off, remove the retaining clip and speed sensor. Then remove the 4 bolts and beat it with a rubber mallet until it slides off.
3) Next, remove the rear cover. There are 3 bolts that are different than the rest. VERY IMPORTANT...MARK WHERE THEY GO!!! The two bolts with the washers are for the guide pins, and right around those there are slots to slide a pry bar under to pry the cover off once unbolted. There is no need to beat it with a rubber mallet.
Once unbolted slide the rear cover off.
4) With the rear cover off, pull the mainshaft and shift rail up and once they are unseated and there is slack in the chain, take the chain off. The pins on the shift fork slide right out of the guide plate on the 231, but require some extra motivation on the 242. (Sorry, I didn't get pictures of this). It should now look like this...
The circled part is high/low range planatary gear assembly. The input shaft is in this.
5) Unbolt the front bearing retainer. There are also prybar slots on this peice, just look around the edge tolocate them.
6) Remove the retaining clip.
With this clip removed, the planatary gear assembly will slide out the back. It should look like this:
7) Remove this retaining clip from the planatary assembly.
The input shaft should slide out.
Here are the input shafts side by side...
Assembly is reverse. Be sure to clean all gasket surfaces and use a 1/8" to 1/4" bead of black or red RTV gasket maker on the rear cover, both bearing retainers, and tailshaft housing. Also make sure the retaining clips didn't get stretched on removal and are seated properly. (One of my clips got messed up). One thing to note, the older transfer cases use a wider input shaft bearing, and I had to put my 231 bearing in the 242 for the 231 input shaft to fit.
Old May 12, 2010 | 01:23 AM
Crazy4x4RT's Avatar
Crazy4x4RT
You can download the parts manual that has an exploded view of the transfer case. Or you can download the full service manual that has detailed explanation of how to take it apart and rebuild it. 95 318SLT did a good write up on a transfer case swap, in which has pics of all the internals.
Edit: 3 mins slow!
Old May 12, 2010 | 01:24 AM
95_318SLT's Avatar
95_318SLT
One step ahead of you!!.... for a change :P
Old May 12, 2010 | 02:40 AM
kikazzdakota
thanks guys ill try it soon gotta get to it want it ready to roll for winter to answer ur question 95_318SLT, i got spun in to the ditch last winter due to ice bout got out when it whent klunk and now i pop it to 4by4 and i cant got over a certain rpm range so i stopped putting it in 4wd now when i hit highway speeds it grinds not bad but constant from bout 15mph to all the way up now im getting a constant klunk at 55 to 60 sounds like tranny too this truck needs a tranny i kno that but i can baby it till next yr but not this grinding noise....
