Rear end temperature?
Old May 18, 2010 | 06:08 PM
Az93DKota's Avatar
Az93DKota
Originally Posted by 95_318SLT
read a thermodynamics and fluid dynamics book for more info! :P
I don't wanna and you can't make me. :-P
All I know is, I used to run 140 in my ZJ. And at the time I lived in Utah and it would get down to 0-5 degrees outside and the axles wouldn't loosen up till I drove it 30+ miles. And when I would go down to AZ in the winter, I would get horrible gas mileage till I hit south of St. George,Ut. Now I run thinner gear oil till I know I'll be hauling something heavy enough to need 140.
Old May 18, 2010 | 06:59 PM
dodgerules86's Avatar
dodgerules86
But straight weight oil gets thinner as it gets hotter because the molecules become excited and spread out as heat is added... read a thermodynamics and fluid dynamics book for more info! :P
(Let this be my occasional post)
Since it's hitting 100+F daily where I am now, let me tell you this: I become less excited as the temperature further exceeds 75.
Old Jun 9, 2010 | 11:53 AM
NorDakota's Avatar
NorDakota
OK...I changed out the gear lube, put 75-90 syn in it. Now when I turn - forward or reverse - I get a clicking, snapping noise. Do I need to add a lsd additive?
Old Jun 9, 2010 | 01:25 PM
Bump's Avatar
Bump
Hey! another Nord-Dakota'r!
Bismarck/Mandan here... good to see a local!
Cant answer your question, just saying hi!
I did put new fluids in both my front and rear dif and just used whatever 75W-90 the local autoparts place had in stock with no additive that I recall....
Old Jun 10, 2010 | 05:12 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Just to point out. Today I drove my truck around the city. A good 1 hour of city driving 40mph tops and stop and go traffic and then towing my trailer just 1 block. And 100 degree weather. I used my Infrared Thermometer.
I got a high of 130 degrees and an average of 120 degrees around the housing and cover.
After 30mins of driving at 75 highway driving I got a high of 150 degrees, average 130 on the housing and cover.
Old Jun 10, 2010 | 05:21 PM
Bump's Avatar
Bump
That sounds reasonable and about what NorDak described: Too hot to holt, but not too hot to touch for a second. you are also turning larger tires than stock. That would create a bit more friction with the more mass, BUT would also make the axels turn slower, right? Might wash in the long run.
