AC/Heat Control Assembly Question
Old May 27, 2010 | 10:11 PM
94DakLover's Avatar
94DakLover
Default AC/Heat Control Assembly Question
When depressing the AC button that consequently lights blue, does this stop coolant flow through the heater core in normal operation?
If yes, is this a vacum or electronic signal? Where does it physically stop the flow of coolant?
Thanks in advance for your time,
94DakLover
Old May 28, 2010 | 12:38 AM
Az93DKota's Avatar
Az93DKota
No it doesn't stop the flow. You can put a valve in line of the heater core in the engine bay. Thats what I did during the summer. My def/dash control door is broke and put a valve in cause the heater is stuck on.
