Overheating problem, need help
Old Jun 19, 2010 | 12:26 AM
kahanabob's Avatar
kahanabob
if you have to get a new radiator do not get one with plastic top and bottom, i did and leaked after one year.
Old Jun 19, 2010 | 09:40 AM
bill55az's Avatar
bill55az
We have a choice? Who makes them with metal tanks? IIRC, someone here got a junkyard radiator from a Japanese car that worked....
Old Jun 19, 2010 | 10:18 AM
shadowthedakota's Avatar
shadowthedakota
iirc, some one said canadian tire sells them. jegs or summit might sell them. all i know is i might go with a deisel radiator for the ultimate cooling power, lol only because its free
Old Jun 19, 2010 | 02:35 PM
kahanabob's Avatar
kahanabob
I live on Maui and found one at at radiator shop, sold it to me unstalled for about the same price that i wasted on the plastic one.
Old Jun 19, 2010 | 04:46 PM
Chris0908's Avatar
Chris0908
When mine went I called the raditor store and they only sell the metal ones for dakotas I think the total bill was $110 but that's over here in New England. Well worth it too cause the ones they sell are tripple core too :-)
Old Jun 19, 2010 | 10:03 PM
Deerkiller9991's Avatar
Deerkiller9991
i have tried everything. water pumps good, flushed it, checked hoses, drained refill, cleaned radiator, EVERYTHING
probably going to get one from the junkyard.
what years will fit? and is there a bigger one that will mount in there? maybe from a ram 2500 truck or van?
Old Jun 20, 2010 | 07:58 PM
Deerkiller9991
back flushed it again. hope it works now. cause its, sometimes, so hot that it spews it out of the overflow
Old Jun 21, 2010 | 12:06 AM
bill55az's Avatar
bill55az
If it overheats with a stock radiator, and it isn't the radiator, putting on a larger radiator is not going to fix it. Why are you sure it isn't the water pump? Also, home flush jobs are too often inadequate . The radiator really should come out and be done at a radiator shop, OR install a new one....
Check for crud built up at the AC condensor, and look carefully between the condensor and the radiator.
I use the shotgun approach, if the radiator has to come out to be worked on, I do the pump and hoses at the same time. No sense tearing it down more than once....
Old Jun 21, 2010 | 01:16 AM
Deerkiller9991
I took my tstat out and that made it stay cooler, atleast below 212 degrees. but how can you tell the temp without a gun? i tested the 212 by putting water on the outside of the radiator and it boiled. but i do know the ignition timings off, so that could be a cause. fix that tomorrow or tuesday. but ill probably buy a new radiator when i get paid. should i get a double or triple core? think thats what its called, the layers?
Old Jun 21, 2010 | 10:15 AM
bill55az's Avatar
bill55az
are you using antifreeze? 50/50 mix?
