1990 dodge dakota 4x4 sport fuel pump issues!
Old Jun 27, 2010 | 04:55 PM
chrisblaze's Avatar
chrisblaze
Default 1990 dodge dakota 4x4 sport fuel pump issues!
To a smaller carter inline fuel pump! Do I
Need all this going on??? I think the guy
I bought it off put a different(older) 3.9 in it!
I'm not to familar with carburated engines nor
Throttle body! The carter on the rail was mounted
There by tie straps!! Why??? The carter inline
Under the hood seems to be the only one working!
Can I just replace tank with new pump and just use
That pump and a fuel filter?? So frustrated!!
I really appreicete the help people!! So frustrated!
Sorry if I posted this in the wrong place...at my
Cottage and don't have a pc!! Dammm cell phones!
Old Jun 27, 2010 | 05:00 PM
chrisblaze's Avatar
chrisblaze
Sorry erased the first few sentences!! 90 dakota, there
Is a in tank fuel pump, then it runs to the rail
To a cater inline pump, then it goes up to the engine
Where there is a pretty small fuel filter then
Old Jun 27, 2010 | 07:36 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Dakota section,
FF
Old Jun 27, 2010 | 08:02 PM
festerw's Avatar
festerw
If it has an in tank pump that is the only one that should be there, unless it is in fact carb'd .
If it's throttle body injection it'll look similar to this with the 2 large injectors on top
Old Jun 30, 2010 | 09:06 PM
chrisblaze's Avatar
chrisblaze
Tks for the replies! Ok so here's where I am with
The dakota! The intank pump had the power wire cut,
The carter fuel pump on the rail was not working,
So I removed it and installed a fuel hose and clamps.
So the only pump left was the smaller carter
Inline pump under the hood. The truck was running great, drove my
Misses to work yesterday things seem great, untill
Driving home, stalled, pulled it over, started and
Then started acting like I was out of fuel! Pulled
Over to side road, pulled it over and wouldn't start!
Sat for about 35 mins, pulled it over and it started
Right up! I guess the first thing I need to know
Is what engine I have???? I have posted some pics
Online for you pros to guide me on what's going on!
If this truck is carbed then I should have a mechcanical
Fuel pump! Can't seem to find where it would mount!
Looked below the alt but couldn't see anything!
Here's the addy where I just posted the pics
http://www.PictureTrail.com/chrisblaze
Tks again for the input!
Old Jun 30, 2010 | 11:39 PM
shadowthedakota's Avatar
shadowthedakota
thats definitely a carb...sorry its kinda outa my expertise
Old Jul 1, 2010 | 07:14 PM
festerw's Avatar
festerw
Yea for sure carbed, the electric pump on the engine is fine it'll only need a few PSI to operate and will serve the same purpose as the mechanical pump. Leave the in tank pump disconnected or you'll flood out and likely damage the carb with too much pressure.
