Which oil pan? Engine? or Transmission?
Old Jul 22, 2010 | 05:31 AM
Calogero's Avatar
Calogero
Default Which oil pan? Engine? or Transmission?
the trans is a 42re factory v6 trans... in my 96 dakota ext cab 2 wheel drive.... the oil pan in the one on the motor from a 97 ram 2500 5.9 4x4..
Old Jul 22, 2010 | 07:48 AM
kahanabob's Avatar
kahanabob
And your question is?
Old Jul 22, 2010 | 08:54 AM
95_318SLT's Avatar
95_318SLT
This.
If you're asking if a factory v6 transmission won't blow to bits behind a 5.9L v8, it will.
If you're asking if a Ram 4x4 oil pan will work on a 2wd Dakota, I don't know. Just compare the shapes, or just go to a junkyard and grab a v8 2wd pan.
Old Jul 23, 2010 | 05:04 AM
Calogero's Avatar
Calogero
Default Works for me!
My trans guy swears he can make my 42re handle the hp of the 5.9....ill try it and see.... The oil pan advice tho, ill compare like you suggested..thanks!
Old Jul 23, 2010 | 11:06 AM
95_318SLT's Avatar
95_318SLT
Ok... yeah, you can make a 42re handle the 5.9, but it won't in it's factory form... especially a used one!
Old Jul 24, 2010 | 02:57 PM
Calogero's Avatar
Calogero
Default original trans question
Thanks for your reply....my question was should i remove the weight on the torque convertor cause the 3.9 is externally balanced and the 5.9 is internally balanced...
