Throttle body to carb
Old Jul 31, 2010 | 07:37 PM
mmanahan1's Avatar
mmanahan1
Default Throttle body to carb
would there be ant advantages to switch over to a carberator and if so how would i go on doing this or is it somthing i should just leave alone
Old Jul 31, 2010 | 07:48 PM
95_318SLT's Avatar
95_318SLT
You would first need to buy a carbbed intake manifold and a carb. Then you would need to get an ignition control system. Then you would need to get a low pressure fuel system. If you have an automatic, you would have to figure out a way to make overdrive work or just simply forget about using overdrive. I'm sure I'm forgetting something... I did a lot of research on this a while ago but my memory sucks.
The only advantages would be the ability to tune it easily and its the cheapest way to get a really high flow intake on the engine. Honestly though, you'd need a big cam and performance heads before you'd need a high flow intake!!
Old Jul 31, 2010 | 07:50 PM
mmanahan1's Avatar
mmanahan1
so there is a lot of work and replacing of parts and adjusting?
Old Aug 1, 2010 | 02:23 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It is NOT worth it. Why are do you want to do it anyway?
Old Aug 1, 2010 | 04:42 AM
shadowthedakota's Avatar
shadowthedakota
you might be able to get the od to still work by forcing it into od. my buddy has to do that with his carberated dodge dart.
but it isn't really worth it because the tuning has to be just right or it won't like to run.
