Trans fluid sample is concerning
Old Aug 5, 2010 | 04:52 PM
issakar's Avatar
issakar
Default Trans fluid sample is concerning
Sup Forum,
so we replaced the NSS on my truck and i gathered about half a quart or so of trans fluid. i started to drain the fluid into the storage container. I noticed the fluid had a bit of "stuf" in it so i gathered it on a paper towel.
here is what i have found:
this is an amount of clutch material. I know some wear would be normal at 165K but i'm not tryin to have to do a rebuild too soon on this guy.
Tell what cha think!
Thx!
Old Aug 5, 2010 | 09:35 PM
tmacdakota's Avatar
tmacdakota
Not knowing the history of your truck, but knowing it has more than 160K miles on it...doesn't look too bad. If it shifts okay and doesn't leak, I would drop the pan and do a fluid/filter change...or at least take it to a shop to do a tranny fluid change on the machine that exchanges the fluid while the truck is running.
Old Aug 7, 2010 | 04:14 AM
dodgerules86's Avatar
dodgerules86
When I dropped my trans pan at about 90K miles or so, I found a piece of metal that my grandpa said looked like a piece of thrust washer (this was a good size piece, like a quarter-moon shape).
Found these pieces TWICE.
Finally replaced the trans at about 105K or so.
The trans didn't give out, but the issue was that if I accelerated too fast from a dead stop on level ground, or accelerated slightly less than just a little on a uphill grade, the trans would shudder.
