major vacuum leak
Old Aug 23, 2010 | 11:01 PM
messing9876's Avatar
messing9876
Default major vacuum leak
I have a 94 sport with a 318. when i start the truck up i can hear a definite "sucking noise". all the vacuum lines are hooked up so im thinking it could be a gasket thats blown. Its also running extremly rich. I want to hear some opinions on this problem. thanks in advance.
Old Aug 23, 2010 | 11:21 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It could be anything from a hose to like you said a bad gasket. The IAC Idle Air Control motor can make that noise as the needle is moved. Take off the air cleaner and check the Throttle Body.
