Rust Problem...
Old Sep 4, 2010 | 04:37 PM
slobS's Avatar
slobS
Default Rust Problem...
Hi,
I have some rust directly above my rear window. It seems as if the previous owner had applied some type of adhesive that ended up causing the rust. Luckily, it has not reached the outline of the rear window. The rust has some light bubbling throughout...
How would you guys suggest I repair this? Any one have some tips? I really don't want it to get any worse than it is.
Thanks.
Old Sep 4, 2010 | 09:02 PM
sammatthews2007's Avatar
sammatthews2007
Apply naval jelly, sand it with a random orbit sander. Repeat until finished. Repaint right away.
Did my entire roof this way. Helps if you leave the naval jelly on a good day in the sun.
Old Sep 4, 2010 | 09:11 PM
sammatthews2007
Some states may have banned naval jelly (silly cancer scare), but I found mine in limited stock in Ace Hardware and Home Depot.
Old Sep 5, 2010 | 04:54 PM
dobaroy's Avatar
dobaroy
What the heck does the naval jelly do ? ?
Old Sep 5, 2010 | 05:33 PM
sammatthews2007
It's a jelly-like substance that chemically breaks up the rust. Believe me, you'll spend all day sanding if you don't use it.
Old Sep 5, 2010 | 06:49 PM
dbilik's Avatar
dbilik
I would POR-15 it if it were my truck, then touch up paint over it, wet sand, then clear coat. Unless you have a paint gun, then you could paint it with automotive paint. Depends on how much time and work you want to put into it. But the POR-15 should stop the rust.
Old Sep 6, 2010 | 07:59 AM
dobaroy's Avatar
dobaroy
Thumbs up
Thanks Sam, wish I would have know about that a long time ago.
