Help replacing intake manifold gasket please!
Old Sep 15, 2010 | 05:41 PM
95dakoder's Avatar
95dakoder
Exclamation Help replacing intake manifold gasket please!
Hello all. I will be replacing my intake manifold gasket for my 5.2L V8 1995 Dodge Dakota. Does anyone know of a good website with step by step instructions and/or pictures for replacing this? I have never worked on this engine before. Thank you for your help!
Rob
Old Sep 15, 2010 | 06:31 PM
sammatthews2007's Avatar
sammatthews2007
It'll probably be easier to get the Haynes manual from your local Auto store. They have step by steps and pictures.
While your intake manifold is off (if you have the time), send it to a local machine shop and have them clean it with glass beads and an acid bath.
Old Sep 15, 2010 | 06:52 PM
festerw's Avatar
festerw
There is a link to the Factory Service Manual in the FAQ it will give you all the info you need. I've done it on 2 trucks it's not hard just time consuming and make sure you've got an inch-pound torque wrench available.
Old Sep 17, 2010 | 05:50 PM
95dakoder's Avatar
95dakoder
Hmm. I clicked on the FAQ link, and I did not see any links in the FAQ section for anything mentioning service manual... where exactly is it?
Old Sep 17, 2010 | 08:00 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Look a few posts above this one. There is a green arrow pointing at it.
Old Sep 17, 2010 | 10:42 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Yeah it equates to about 12 foot pounds on the bolts. That's not much but DON'T go over. Just clean it VERY well before you re-assemble. Put a little dab of engine RTV in the corners. Get a buddy to help you drop it back on, it helps alot if you have short legs like me and you have to climb up on it and hover over the engine.
