Water Leak on Passenger Side
I got this water leak somewhere. Started happening within the past month. The passenger side floor is flooding with water whenever it rains. Had the same problem on my '84 Dakota but never figgured out where the leak is. Anyone have a solution for this?
Thanks
Thanks
your wiper crowl is got leaves and sticks in it. i HAD TO SAME PROBLEM IN MY 91 AND 93 DAKOTA. all i did is take the hose and spray the crap out of the wiper cowl holes and cracks. also cleaning out all the weather stripping in the doors and the one under the hood.
Hope this helps ,Logan
did a google search and came up with the answer on another forum.
The leak is at the seam between the roof and the rear side panel (extended cab). Externally you see a "divider" (I'll call it) of about 1/2 inch. This can be removed by removing the inner side panel plastic and the headliner. In there is a sealed joint. This "sealer" deteriorates and allows water to drain down inside to the floor, thus flooding the floor. This could happen on either side of the truck. Silicone it all up and all is well.
