whats this hose called?
Old Oct 7, 2010 | 06:16 AM
mdhutch's Avatar
mdhutch
Default whats this hose called?
On a 95 4cyl
Not the upper or lower radiator hose. But on the thermostate housing, the upper radiator hose connects and another smaller hose connects. This smaller hose goes behind the engine and connects to a area under the throttle body.
Any ideas as to what this hose is called. Every hose that autozone or advance auto shows me doesn't look right.
Thanks
Hutch
Old Oct 7, 2010 | 11:56 AM
fox's Avatar
fox
sounds like your bypass hose go to rockauto.com put in your vehicle info then go to the cooling system folder & click on bypass hose whole bunch of them on there.
Old Oct 7, 2010 | 01:04 PM
Crazy4x4RT's Avatar
Crazy4x4RT
A pic is always best. I'm guessing it is the Heated intake hose. See this pic.
Old Oct 7, 2010 | 05:04 PM
mdhutch's Avatar
mdhutch
That looks like it, the heated intake hose. However, mine does not go all the way to the heater core. It stops at the TB area, then via another connection comes back out.
So could this still be the same hose you think??
Thanks,
Hutch
