Steering wheel trim removal (pic)
Old Oct 17, 2010 | 04:58 PM
Deerkiller9991's Avatar
Deerkiller9991
Default Steering wheel trim removal (pic)
I cannot figure out how to get this off!!! i removed the 2 bolts underneath and it looks like it should come off, half of it does but i dont want to try pulling to hard and break it. am i missing something or do i just have to pull with some tough love? it has tilt steering wheel etc. 1991 if that makes a diff. and if anyone knows what color the cruise control wires are for the steering wheel that would be great lol, wanna hook the on/off to my fog lights and the other 2 to my horns and siren
Old Oct 17, 2010 | 05:31 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The FAQ has a wiring diagram for a 91. There are 3 screws. The two in front, and 1 more just above the pannel under the dash, right where the rubber seal is.
Old Oct 17, 2010 | 08:20 PM
issakar's Avatar
issakar
I think it's cool that you are going to integrate your lights and such into the steering wheel. I assume you're saying you will use the cruise control buttons to control your peripherals? Cool idea. Does your cruise control not work? jw. Dig it
Old Oct 18, 2010 | 12:19 AM
Deerkiller9991
well i got it off and only broke a tiny piece lol but thanks crazy, didnt even think to check the faqs, but the cruise control works...kinda. it didnt work before but i cant figure out like where the wires connect through the steering wheel. like if theirs 2 metal plates or something so the wires dont twist with the wheel...hmm....have to figure that out
Old Oct 18, 2010 | 12:43 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It is called a clock spring. It is a a coiled wire wrapped around it self, so as you turn it coils and uncoils. It is in between the steering wheel mounting plate and the steering column.
Old Oct 19, 2010 | 10:25 PM
shadowthedakota's Avatar
shadowthedakota
i tired running my foglights to my o/d switch after teh trans swap but the button doesn't work like that. it can ,however, be used as a horn button or something of that nature.
