94 Dakota code 27
Old Oct 20, 2010 | 04:22 PM
creative-customs's Avatar
creative-customs
Default 94 Dakota code 27
My 94 dakota 318 4x4 had check engine light on, drove to the gas station shut the truck off went inside came back turned it on, no engine light? I checked the codes, and want to know if there is a specific reason code 27 flashes twice? starts as 12, normal, then 2 27's, and the finishing 55. I know what the codes are, just curious about the 27 flashing twice. Thanks
Old Oct 20, 2010 | 04:31 PM
Crazy4x4RT's Avatar
Crazy4x4RT
How was the engine? Has it been missing, shaking? Code 27* Injector control circuit failure.
Maybe 2 injectors failed, which would cause a miss. You would fell it shaking bad.
If you get a code reader/scanner it can tell you which injectors were acting up. Autozone can do it for free, as well as others.
If the engine is running fine, try resetting the computer by disconnecting the battery for a min. Then see if the code comes back up.
Old Oct 20, 2010 | 05:27 PM
creative-customs
The engine seems to run just fine, no miss or shaking. I didnt even think to reset it, I will try that today. I didnt realize i could use a code reader/scanner on a 94.
Old Oct 21, 2010 | 03:37 PM
creative-customs
Disconnected the battery today, no luck, same codes.
Old Oct 21, 2010 | 04:30 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Check your connectors ect.
