Sas swap help please!!!!!!!!!!!!!
Old Nov 1, 2010 | 04:29 PM
logancounterman's Avatar
logancounterman
Default Sas swap help please!!!!!!!!!!!!!
ok i have a 1991 dodge dakota 318v8 4x4
and i am talking to someone about a trade for other stuff.
ok heres the questain.
Can i put a 76 fj40 front axle in the front of my dakota.
yea i know i will need a matching rear axle thats not my problem.
and i can get one. but my main questain is can i put leaf springs on the front of a dakota and how much work is it.
i have seen poeple do 4 link, and 3 link but can i do leaf springs in the front of a dakota. please let me know i can do it but is the frame there to do it.
please help..............................
if a toyota can do y not a dakota.
Old Nov 1, 2010 | 04:44 PM
95_318SLT's Avatar
95_318SLT
Yes, you can put leaf springs on the front of a dakota. I've seen it done... there is even a write up on here where a member did it.
As for the fj40 axle... my guess is it will be too narrow, but get the measurements and find out. No matter what axle you get, you'll have to cut the factory spring perches off and weld your own on making sure you have the correct pinion angle and castor angle.
I put a '78 F250 HD Dana 44 under my truck with a 3 link/coil spring setup. Its wide, but I'd much rather have it too wide to keep the truck more stable on off-camber trails.
Old Nov 1, 2010 | 06:09 PM
logancounterman
coooooool thanks i'lll check into the axle size. it would be really cool to but a axle in the front and left it and but 39's on it.
Old Nov 1, 2010 | 07:20 PM
Hahns5.2's Avatar
Hahns5.2
I would guess that Toy axle is also a passenger drop as well...
Old Nov 1, 2010 | 07:39 PM
logancounterman
ok is there a axle that will work with the axle that is already in the rear of my 91 dodge dakota.
Old Nov 1, 2010 | 09:05 PM
95_318SLT's Avatar
95_318SLT
Your rear axle should have a 6x4.5 lug pattern, so no, there is no solid front axle that will match it. I put 3/4 ton axles under my truck front and back with the 8x6.5 lug pattern.
And good point Hahns5.2... you will need a driver's side drop axle. No chevy axle will work. A few dodge axles will work, but the late '70s Ford axles are your best bet.
