Changing timing chain
Old Nov 6, 2010 | 01:38 AM
ddgdkt96's Avatar
ddgdkt96
Default Changing timing chain
Hello all,
I am changing out my timing chain in a week or so, its making a lot of noise, and I hate noise. My question is this, will it help the performance at all? Currently she drives like an old lady on a cheese diet. I am guessing the cat might be a little plugged, but hoping the timing chain will make a difference. Also, my gas mileage is crap, 15mpg. might that improve?
thanks
Old Nov 6, 2010 | 02:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Compared to the way it drives now yes the performance MPG will improve.
Old Nov 6, 2010 | 09:45 AM
gladiator's Avatar
gladiator
just in case: there is a procedure in the FSM to check for chain slack without tearing into the engine.
Old Nov 21, 2010 | 09:57 AM
ddgdkt96's Avatar
ddgdkt96
well we got her done, with no problems. It did seem rather dry inside the housing, but it had been sitting for 3 weeks. She runs better (I think), but now I can hear another rattle, this one I think is coming from my Cat. that is Catalytic converter not the stray cat in my yard. I had everything lined up just the way it says so in the manual, and when I put it back together it went like it should. Here is my question.
Is there anything else I need to do regarding my timing?
Old Nov 25, 2010 | 12:09 AM
413maxwedge's Avatar
413maxwedge
As long as you lined the dots up right you should be fine you can double check it if you wish to.
