transmission mount for 93 5.2 4x4?
Old Nov 9, 2010 | 10:34 PM
93DakotaMagnumV8's Avatar
93DakotaMagnumV8
Exclamation transmission mount for 93 5.2 4x4?
does anyone know where i can get a transmission mount for 93 dakota 5.2 auto 4x4? dodge says they were discontinued from 91-94.. i need a new one after replacing a transmission with over 240,000 miles. it is in two pieces.
Old Nov 9, 2010 | 10:47 PM
Crazy4x4RT's Avatar
Crazy4x4RT
www.autozone.com or www.napaonline.com
Old Nov 10, 2010 | 12:09 PM
93DakotaMagnumV8
those are the wrong ones. i ordered one from napa and it was wrong and autozone and oreillys are wrong, mine has 2 bolts to transmission and two bolts to crossmember. dodge said they discontinued from 91-94 and mine is a 93.
Old Nov 10, 2010 | 01:05 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Are you sure you have the correct one on your truck. Factory has 2 bolts to the top and 4 on the bottom.
Maybe someone swapped out yours for the wrong one.
Check out Napa. They have the correct one for 93 4x4 5.2 auto. http://www.napaonline.com/Search/Res...99&Ntk=Keyword
Maybe they swapped in a manual transmission mount or something else. Look up for a manual transmission mount. But 5.2's didn't come with them in 93. Only V6 did.
Also you can always double check the parts manual. Here you can see the correct mount for 93 4x4 5.2 auto.
