1997 5.9 tps setting
Old Nov 10, 2010 | 05:32 PM
A_POLVADO's Avatar
A_POLVADO
Default 1997 5.9 tps setting
i HAVE A 97 5.9 MAGNUM WITH CAM ,M1 INTAKE AND OTHER MODS
WHAT IS THE INITIAL VOLTS ON THE TPS SUPPOSED TO BE SET AT I HAVE A STUMBLE OFF IDLE AFTER PUTTING A NEW TPS ON THE TRUCK.
Old Nov 10, 2010 | 07:16 PM
JGC403's Avatar
JGC403
You can't adjust the TPS.
Old Nov 10, 2010 | 08:42 PM
9652dakota's Avatar
9652dakota
you either have to use the drb3 (dealer scanner) to reset the min tps voltage or you have to unhook the bat for ten mins to let it reset. aftwards you turn the on but not start it. let it set for 30 seconds and the pcm should relearn the min tps. there is no adjustment and this value can change some over time so the pcm does update it.
also if you think your tps is bad back probe it. should be .5 to 4.5 volts. the 0 to 0.5 and 4.5 to 5 volts are reserved for self diag as ckt codes.
