Fuel rail compatibility problems
Old Nov 17, 2010 | 08:28 AM
dbilik's Avatar
dbilik
Default Fuel rail compatibility problems
So here is the issue. I used a fuel rail from the 96 Ram I got my donor engine out of to replace the current 360 in place. The old fuel rail had a slice in the fuel line. The new rail has a female connector on it, as does the fuel line itself. The new fuel rail is nicer IMO, made out of plastic and won't rust like the old metal one. I almost think I need a male to male piece of hard line in between to join them now, but I don't think such a line exist. Any ideas?
Old Fuel rail...
New fuel rail next to old fuel rail....
Existing fuel line and old fuel rail....
Old Nov 17, 2010 | 09:40 AM
shadowthedakota's Avatar
shadowthedakota
maybe a piece of high pressure fuel line with 2hose clamps on each end would work.
Old Nov 17, 2010 | 04:26 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya maybe a rubber hose. Or make some flare ends with some threaded connector. Use a brake line in between. Or see if you can find a stock setup like yours at the Junkyard.
