Leveling kit
So i cant find a shop to install my kit, they all claim as soon as I get the kit they can put it in for real cheap!!! yeah right...
How do you install a leveling kit I have no clue where to start. It has blocks, u bolts a good amount of hardware and torsion keys.
Thanks in advance
Thanks in advance
It won't be hard at all. For the torsion bar keys, lift up the front. Unbolt the old key and install the new one. Take a measurement before so you can add in the height you want.
For the rear Unbolt the old U bolts. Then jack up the truck till you can slide in the spacers. Then bolt up the new U bolts.
We have a link in the FAQ. www.ebay.com is another source.
Also to add a Leveling kit just lifts the front. Levels the front to the rear.
A Lift kit lifts front and rear.
A simple leveling kit is to crank up your torsion bars. Its free.
Is removing the torsion keys simple as unbolting them and replacing? Sorry, never done it, ive been reading about the pullers and c clamps and dont have either, is it too dangerous to do myself?
Putting the blocks in the rear is easy enough, the torsion keys is where I am confused, I pretty much just know where they are at.
yeah I got it on ebay, just search dodge dakota leveling kit, comes with blocks u bolts and keys. Looks to be good quality but only time will tell.
How am I going to just unbolt it with all the tension from the torsion key? Wont i need a heavy duty c clamp to pin it down and then unbolt it?
