New axle older truck
Old Nov 20, 2010 | 10:29 PM
Motoy's Avatar
Motoy
Default New axle older truck
Can I put an 8 1/4 rear end from a 2002 dakota in a 1993 dakota?
I have a line on a 2002 with 3.55 gears (same as my current) but it also has a lot less miles and a limited slip differential.
thanks guys
Old Nov 20, 2010 | 10:34 PM
VINCE 91's Avatar
VINCE 91
I do a little work with wrecking yards because of my job. Lots of times the guys there have a lot of info on what years will interchange. I am lucky and get great accurate responses. Give it a try, but get a couple of answers. There is always that one guy....
Old Nov 21, 2010 | 02:05 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It will work. If you have 2wd, you will need a 2wd axle. Same for 4wd. The shock mounts on the newer axle are different. 1 shock will work 1 will need to have a bracket welded on.
Old Nov 21, 2010 | 08:25 AM
dobaroy's Avatar
dobaroy
If all the swap takes is to weld the shock bracket on, then it would be worth getting the limited slip. Good luck with it.
