Stall when going into gear when hot
Old Nov 22, 2010 | 08:35 PM
FearThis94's Avatar
FearThis94
Default Stall when going into gear when hot
I changed the fuel rail and line ad o-rings (had a leak at the rail) truck ran perfect with none of these symptoms before I changed it. Also I cleaned the TB (hosed it good) while it was off. I have changed all the sensors on the tb and still no luck. It revs up about 500 rpm when I let off the gas and bumps hard when i shift into gear now. Got a check engine light that gives the code 22 (temp sensor bad) Is this realy the problem or am I missing something 94 Dakota 4x4 5.2
Old Nov 23, 2010 | 12:39 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it can be the temp sensor. There are 2. One 1 wire for the gauge. One 2 wire for the computer. Change the 2 wire.
Old Nov 23, 2010 | 09:10 PM
FearThis94's Avatar
FearThis94
Cool, thanks. i picked up the part today and wondered why it had 2 prongs. Where is the 2 wire located?
Old Nov 24, 2010 | 12:42 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Both are next to the thermostat housing.
Old Nov 24, 2010 | 02:14 AM
FearThis94's Avatar
FearThis94
Found the problem. The harness came off when I did the fuel rail Thanks for the help Crazy.
