90 Dakota, no brake pressure after...
Old Dec 18, 2010 | 03:15 PM
draftrider's Avatar
draftrider
Angry 90 Dakota, no brake pressure after...
I just did a front brake job and now, there is no brake pressure at all. Pedal goes all the way to the floor and the Anti-lock light came on. I have check for fluid leaks and found none. I don't want to have to tow it to a shop if it's something simple.
Old Dec 18, 2010 | 03:22 PM
declid's Avatar
declid
did u just change pad, if so u have to pump them 3-4 times to get the cyl out again, tom
Old Dec 18, 2010 | 03:25 PM
swapdip's Avatar
swapdip
You may need to bleed the brakes.
Old Dec 18, 2010 | 10:29 PM
draftrider's Avatar
draftrider
There is fluid to the top of the reservoir. I checked the brake piston, it did expand back out. No leaks that I can find.
Old Dec 19, 2010 | 07:36 AM
declid's Avatar
declid
u may have ruined the mater cyl by pushing all the way to the floor, the cyl builds up crud ,because for yrs it only went so far down,then u go and push past that ridge and it ruin ins the rubbers, i would get a new master cyl, just to be safe, tom
