No reverse 1995 dodge dakota
Old Jan 1, 2011 | 03:17 PM
Dave64's Avatar
Dave64
Default No reverse 1995 dodge dakota
I was trying to get out of a snow drift by rocking forward and backward. I did get out but I think I broke something. Now it won't go into reverse. Everything else seems to be ok. About a month ago it did have a little problem going into reverse unless I revved up the engine a little. It would go into gear with a clunk. I thought this was a fluid problem so I filled the trans fluid up.
After this problem I can't say that I've had any problems to mention here.
My truck has 177k miles and I haven't serviced it as I should have this last year. I've owned the truck for two years.
Old Jan 1, 2011 | 03:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It may be the fluid. It may be the bands that need adjusting. Check this post. https://dodgeforum.com/forum/1st-gen...agnostics.html
Old Jan 18, 2011 | 12:31 PM
PhillyLee's Avatar
PhillyLee
My wife's car was doing the same thing. Let me ask you this... If your on a hill pointing down, and put it in reverse and hit the gas, does it just roll forward?
Old Jan 19, 2011 | 10:21 AM
misfitdakota_95's Avatar
misfitdakota_95
I'm willing to bet that the low/reverse band is broken. It does happen on these transmissions. The only way to fix it is the disassemble the transmission, i.e. rebuild.
