Grill swap
Does the post 91' grill bolt to the earlier models? I know that the front is different, but just curious about between the light housings. I would rather have the DODGE top badge.
You will have to swap the radiator core, hood, grill and lights and side housings. If you find a junkyard one or a craigslist special. The 91-up radiator cores are moved up an inch or so to clear V8's with fans. So for your swap this might be a perfect mod.
I do prefer the 91-up grill/headlight assembly too.
The other day I saw a convertible with the updated front end, so I think it would simplify my front cooling issue to go ahead and do this. Anyone that has done this, did you have to update your bumper as well? Also, who are the primary/recommended fiberglass hood providers for a non-cowl induction type hood. While I have no current cooling issues to speak of with my pusher fan setup, I would rather have a direct drive fan with cowl for simplicity and less wiring.
