Exhaust & Cat Issues
Old Feb 12, 2011 | 08:30 PM
Maynard70's Avatar
Maynard70
Question Exhaust & Cat Issues
Hi Guys...
New here, just picked up an '89 with the 3.9 and 5-speed. It runs, drives, and stops. Barely.
I bought it on the cheap; I changed the oil, replaced the plugs and wires, flushed the radiator, etc. Still runs like crap. It still needs a muffler, so I'm in the process of exhaust replacement, and think the cat might be plugged up (stuttering, backfires, etc.). Thinking about just running a straight pipe to Auto Zone special muffler.
We have no emissions testing where I live, so I'm thinking about taking the sawzall to the cat. Anything I should know before I do? I know very little about these engines. Will the computer give me problems, or does it care? I spied what looked to be a sensor tube on the side of the cat, but I'm not sure what it connects to or if it's even working.
Anyone have any experience with the cat removal on the 89 V6s? Any thoughts?
Thanks.... M
Old Feb 12, 2011 | 11:44 PM
kahanabob's Avatar
kahanabob
that is an air tube that supplys fersh air into the cat if you trace it back up to the engine you will find it connects into the air pump. don't take anything off past that and you will be fine. i would re rout it maybe into the intake or just let it pump air out under the hood. . might want to just gut out the cat and put the unit back with the tube still on it......i am in the process of doing the same
