Dead spot on acceleration
Hello all,
I have a 96 dak, with 206k on her,3.9L with an AT and a towing package.
anyway, when I accelerate on the freeway, there is a dead spot when I hit the throttle, and then finally it gives a little juice and the trani shifts down, and its good. but there is the dead spot and it makes it run doggy.
The truck is white if that makes a difference.
thanks in advance
P
thanks in advance
P
Thanks Crazy and Dave,
I am going to investigate the cable adjustment, although it is fine at low speeds.
There are no codes, and I have a new TPS in.
I also just had my fuel injectors cleaned and its a little better, but I can still feel the doggyness and the dead spot.
I will keep you posted, thanks
