front end grind
Old Mar 5, 2011 | 11:21 AM
new2mud's Avatar
new2mud
Default front end grind
just installed new 31's.tires clear even with a tight radius turn.Now in 4 wheel peel I get a grinding noise from the front when turning slowly.Any suggestions would be great thx in advance!
Old Mar 5, 2011 | 12:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Don't know what you mean by 4 Wheel peel but if your using 4wd on the pavement you can cause some breakage.
As for the sound it could be anything. Just take a look. Start with brakes and anything the tire/rim could touch.
Old Mar 5, 2011 | 05:39 PM
melodytoinvent's Avatar
melodytoinvent
i bet its just your tires rubbing. mine did pretty bad at first till they rubbed and ground the inside of the wheel well down lol
Old Mar 7, 2011 | 02:54 PM
mazda7475's Avatar
mazda7475
might be worn CV joint.
