swapping motors
Old Mar 12, 2011 | 04:15 AM
ink_fuz's Avatar
ink_fuz
Default swapping motors
hey guys can i swap a 94 Dakota motor and put it in a 92 Dakota will the tranny bolt up , and if not well i have one for parts any help is needed thanks
Old Mar 12, 2011 | 10:38 AM
melodytoinvent's Avatar
melodytoinvent
check the faq2 sticky a few posts above this one. but what engine and tranny do they both have in them? are you just replacing a v6 or upgrading to a v8? we cant tell you much if we dont know what exactly you have. v6 replacement is an obvious yeah. v6 to v8 requires certain v8 parts like the flywheel i believe and the v8 tranny or an upgraded one to handle more power. but yeah..details man lol and then we can help ya.
Old Mar 12, 2011 | 12:46 PM
ink_fuz's Avatar
ink_fuz
huh ok, again i want to take a v8 out of a 94 and put it in a 92 that has a v8 in it can this be done since they are bolth v8s will the 94 motor bolt to the 92 tranny
Old Mar 12, 2011 | 01:35 PM
melodytoinvent
okay yeah im pretty sure that will work just fine. Are they both automatic or manual?
Old Mar 12, 2011 | 03:24 PM
ink_fuz's Avatar
ink_fuz
they are bolth auto 4wheel drives i was told the trannys in both of them have different bolt patterns , so what u are telling me is that i can put a 94 v8 auto in a 92 v8 auto ?
Old Mar 12, 2011 | 05:22 PM
melodytoinvent
should be able to. As far as i know there werent any transmission changes around then so yeah they should bolt right up.
Old Mar 12, 2011 | 05:28 PM
melodytoinvent
look over the faq2 sticky thread. it has all the info youll need about the engine swap and more.
Old Mar 12, 2011 | 05:40 PM
ink_fuz's Avatar
ink_fuz
the 92 tranny what else did the put it in besides Dakotas
Old Mar 12, 2011 | 07:19 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I posted the answer in regards to your other post.
The 92-95 Dakota and Ram and Van V8 5.2 and 5.9 came with the 46rh.
Old Mar 12, 2011 | 09:06 PM
ink_fuz's Avatar
ink_fuz
hmm are u sure about that im being told other wise about the tranys like u can not put a tranny from a 92 to a 94 if they are bolth v8s and autos they tell me that if wont work also if i was to replace the trany in my 92 it has to be from a 92 to 93 only and that 94to 96 will not work and help with this thanks
