93 dodge dakota steerting
Old Mar 13, 2011 | 09:52 AM
93dodgedakota's Avatar
93dodgedakota
Arrow 93 dodge dakota steerting
is there any way to tighten up the steering
Old Mar 13, 2011 | 11:35 AM
kahanabob's Avatar
kahanabob
i can only speak for 2WD...check you rack&pinion make sure it is secure to the frame, mine came loose and it effected the steering. next there is a adjustment screw on top of the steering box. you loosen the nut and tighten the screw a little at a time then tighten the nut back down.
Old Mar 13, 2011 | 01:38 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Most likely it is loose for a reason. Bad ball joints, tie rod ends ect.
Old Mar 14, 2011 | 11:25 PM
garyjrsonny's Avatar
garyjrsonny
i completly redone mine, and the only thing that showed wear on mine was idler arm. youll just have to inspect. but if or after all your joints are good you can adjust gear box like kahakabob said, i think 1/4 of a turn will equal about a inch in stearing wheel.
Old Mar 15, 2011 | 10:25 AM
93dodgedakota
when I turn the wheel it takes about an inch and a half b4 it starts to turn ither way...Im gonna have to look into this deeper like you guys said...to check the ball joints and stuff do i jack up the truck and try to move the wheels?
Old Mar 15, 2011 | 12:04 PM
kahanabob's Avatar
kahanabob
jack up enough to get something like a 2x4 or crowbar under the tire. with the end of the 2x4 under the tire put a small block under the 2x4 so you can push down on it and it will apply upward lift on the wheel. check for up&down play. whith the truck on the ground have someone turn the wheel back and forth while you watch the tierod end ball joints to check for play.
Old Mar 15, 2011 | 08:20 PM
shadowthedakota's Avatar
shadowthedakota
see if your tie rods jumped threads too...
