Allignment
Old Mar 16, 2011 | 11:08 AM
InnerCityHillBilly's Avatar
InnerCityHillBilly
Default Allignment
If i where to raise just one side, cause i have sag on the left side only, what area of alignment would i need to adjust, like camber toe caster
Old Mar 16, 2011 | 11:18 AM
95_318SLT's Avatar
95_318SLT
Any changes you make to the front suspension will throw off all parts of the alignment.
Old Mar 16, 2011 | 11:21 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Its hard to say. It all depends on your truck, how high you need to put it and where exactly your current alignment adjustments is at. Camber and caster if it is that far off. Toe maybe due to moving the control arm. So it is best to get it aligned after lifting, if it is a small amount you may be okay, but aligning is best.
Old Mar 16, 2011 | 11:43 AM
InnerCityHillBilly
it wouldnt be anything past stock height or leveling it to the right side, the rear is real low and i have plans on fixin it
