2"/4" drop
hey everyone im new to the site and i was looking over some threads on lowering 96 dakota's but couldnt find anything in particular . i was just wondering if anyone knows what all i need to lower me dakota
The FAQ2 in this section has all the info you want. Just a few posts above this one.
Lowering
________________________________________
2wd
http://www.belltech.com/
http://www.sporttruckdirect.com/dako...html#oldDakota
http://www.doetsch-shocks.com/34.asp
http://www.stillen.com/product.asp?i...LES&c=SU&m=all
http://airbagit-store.com/default.asp?redir=1
For the rear just use spring blocks, or longer spring shackles.
Universal air bags. https://airbagit.com/index.php?osCsi...beeed6ca3c2580
http://www.streetbeatcustoms.com/
If you got a v8 you can get v6 coils, you can heat the springs, You can cut the springs.
Or flip your shackle hangers. Check out https://dodgeforum.com/forum/1st-gen-...ut-blocks.html
https://dodgeforum.com/forum/1st-gen-...le-hanger.html
4wd
http://www.totalperformanceonline.co...ayout_0100.xsl
If you got a v8 you can get v6 torsion bars. You can crank down the torsion bars. For the rear use longer spring shackles or do a spring under axle swap. Some have token out some springs from the spring pack.
Or flip your shackle hangers. Check out https://dodgeforum.com/forum/1st-gen-...ut-blocks.html https://dodgeforum.com/forum/1st-gen-...le-hanger.html
2wd
4wd
