Another front rotor question
Old Mar 31, 2011 | 11:46 AM
kahanabob's Avatar
kahanabob
Default Another front rotor question
if i have to get new ones will i have to press out the wheel bearings from the old ones since mine is the entire hub assembaly? any issues i need to know about? going to try to get them turned.
1990 V6
Old Mar 31, 2011 | 12:29 PM
misfitdakota_95's Avatar
misfitdakota_95
once you remove the rotors from the spindle, the front bearing comes off and the rear will come out once the rear grease seal is removed. When you buy new rotors, they will already have new races already pressed on, so all you have to do is pack the bearings, install new grease seals, adjust your bearings and your done.
