5.2L air cleaner size?
Old Apr 3, 2011 | 04:07 PM
DakotaX2's Avatar
DakotaX2
Default 5.2L air cleaner size?
I want to replace the stock air cleaner (1995) as it has the hose missing anyway with a after market old school type. Chrome I guess, if that is all that you can get these days. I thought someone may know off the top of their head the diameter size of what the cleaner needs to be. Thanks for any help, or maybe a brand or part number would be great. I thought about a newer version, or just buying a high performance type and putting the OE one from my 00 5.9L RT onto the 4X4 Dak. If that size is the same?
Old Apr 3, 2011 | 05:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The throttle body end is 5in round, which is the most common size out there and most 4b carbs. The filter size is up to you. I have the K&N air filter with the X-Stream top. 14in x 3in.
Old Apr 4, 2011 | 05:22 PM
DakotaX2's Avatar
DakotaX2
Thanks for the reply...
Old Apr 6, 2011 | 01:27 PM
9652dakota's Avatar
9652dakota
i used the hat from a 98 durango 5.9 and a cold air for the second gen with some aluminum dryer duct to make a cold air for myne. i had one like yours crazy and the high engine bay temps were killing my intake air temps. im almost 100 degrees cooler now. and it does make a diff in my mind.
