Band adjustment specs '95 Dakota
Old Apr 4, 2011 | 11:41 AM
PapaCope's Avatar
PapaCope
Default Band adjustment specs '95 Dakota
I have a 95 Dakota 5.2 V8. I need the adjustment specs on the transmission bands. Thanks in advance
Old Apr 4, 2011 | 12:17 PM
siggie30's Avatar
siggie30
Front Band
  • 42RH - tighten to 72 in-lb, back off 2-1/4 turns
  • 46RH - tighten to 72 in-lb, back off 2-7/8 turns
  • 47RH - tighten to 72 in-lb, back off 1-7/8 turns
Rear Band
  • 42RE/RH - tighten to 72 in-lb, back off 4 turns
  • 46RE/RH - tighten to 72 in-lb, back off 2 turns
  • 47RE/RH - tighten to 72 in-lb, back off 3 turns
From dodgeram.org for 95-96 A518 style trans (ie 46rh)
Old Apr 4, 2011 | 12:21 PM
PapaCope's Avatar
PapaCope
Originally Posted by siggie30
Front Band
Rear Band
Thanks for the response. I found the link for the factory manual, and downloaded it.
Old Apr 5, 2011 | 09:12 PM
DakotaX2's Avatar
DakotaX2
Can you drop the pan without removing the Y pipe?
Old Apr 5, 2011 | 09:46 PM
shadowthedakota's Avatar
shadowthedakota
yes...
