o/d in & out
Old Apr 4, 2011 | 08:40 PM
bobby chabby's Avatar
bobby chabby
Default o/d in & out
well the o/d started working in my 91 dakota le (4x4 318) . the only thing is around 35 mph & 45 - 50 mph the o/d engages but will kick in and out of o/d.
back & forth . i'm starting to figure out how to give the truck gas and let off the gas to keep the o/d engaged, but it doesn't seem to always work .
anyone ever had this problem?
Old Apr 5, 2011 | 01:09 AM
festerw's Avatar
festerw
Look above in the FAQ thread on how to adjust the kick down cable.
EDIT: Here is the thread
https://dodgeforum.com/forum/1st-gen-dakota-tech/223570-throttle-valve-tv-cable-adjustment.html
Old Apr 5, 2011 | 10:23 AM
bowhunter2k9's Avatar
bowhunter2k9
mine did the same thing, I had to get a new speed sensor. Its below the truck right behind the transfer case.
Old Apr 5, 2011 | 07:24 PM
bobby chabby
thanks for the info.
i'll check both of those things out in the next couple of weekends
Old May 2, 2011 | 09:19 PM
bobby chabby
well, i finally got around to checking out these o/d suggestions. tracked down the speed sensor and found the wire next to where the speedometer cable comes into the sensor was disconnected . connected it back, tie wired it for added security, and i've got o/d . thanks for the help . makes this woodpecker feel like a motorhead
