94 dak ext cab mounts
Old Apr 10, 2011 | 09:06 PM
vulch's Avatar
vulch
New Member
Default 94 dak ext cab mounts
Hi i need to replace some cab mounts where can i get some and what parts do they consist of looks like from the bottom ,metal washer . then rubber mount, is there another washer on top of the rubber mount ,then the upper mount is there a diagram some where .And where can i get a body lift kit
Old Apr 10, 2011 | 10:05 PM
festerw's Avatar
festerw
I used Energy Suspensions body mounts from a 2nd gen and the cups from a 1/2 ton Chevy.
Body lifts can be had from Summit Racing.
Old Apr 10, 2011 | 10:14 PM
vulch's Avatar
vulch
New Member
Thanks does anyone have a pic of factory mounts .when installing a 2" lift do you remove the top factory mount
Old Apr 10, 2011 | 11:48 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I bought my replacements from my local Dealer. Napa might have them. When installing a body lift, install it on top of stock mounts. Here is a quick one found on Google.
Old Apr 11, 2011 | 07:26 AM
vulch's Avatar
vulch
New Member
Thanks for pic that explains everything
Old Apr 11, 2011 | 09:21 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Google is your friend!
