mopar brand trans fluid vs dex2 and other brands
Old Apr 11, 2011 | 10:18 AM
Frogman's Avatar
Frogman
Default mopar brand trans fluid vs dex2 and other brands
i have a 88 and a 90 dakata. both dipsticks say right on then use mopar atf or dextron2. i was told to use atf+4 which i did use. it was a generic brand that i used. i talke dot another dakota guy the other day who said he was told to do a fluid change from atf+4 to mopar brand to fix his shifting problem. he said he did it and his problem went away. is it true that mopar brand may have a better api ratign than othe fluids and work better than atf+4 in a dex2 compatible vehicle?
Old Apr 11, 2011 | 11:05 AM
siggie30's Avatar
siggie30
There are mixed reviews on the subject. I have heard to use atf or dextron 3 for that era of transmission. If you use the mopar brand then your going with the factory recommendation.
Old Apr 11, 2011 | 05:26 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If you can't do Mopar brand I would suggest stick to the ATF+3 and higher. Regular ATF and Dextron has been known to give problems.
Old Apr 12, 2011 | 01:57 AM
dakotamandan's Avatar
dakotamandan
Any of these should be fine. I would only use ATF+4: http://www.centerforqa.com/licensedatf4brands.html
Old Apr 12, 2011 | 04:07 AM
96magnumram's Avatar
96magnumram
My oil company packages motor oil and ATF for Advance Auto Parts...their ATF+4 is blended by Ashland (Valvoline), shipped to us in rail cars and labeled Advance Auto Parts ATF+4...
Old Apr 12, 2011 | 09:10 AM
Frogman's Avatar
Frogman
i guess that is what i should have asked is who packages mopar brand. thank you. i will try to find that out. isnt it funny how a person always seems to ask a question in a wrong way sometimes. thanks for straightening me out.
Old Apr 14, 2011 | 12:36 PM
misfitdakota_95's Avatar
misfitdakota_95
In case there is ever a question about Mopar ATF+4, its usage, applications, etc. here's the TSB directly from Chrysler:
NUMBER: 21-014-07
GROUP: Transmission
DATE: October 16, 2007
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-010-06, DATED APRIL 14, 2006, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES THE ADDITION OF THE ASIAN WARNER (AW4) TRANSMISSION AND ADDITIONAL MODELS AND YEARS.
SUBJECT:
Automatic Transmission Fluid Usage ATF+4 (Type M59602)
MODELS:
1989 - 1995 (AA) Spirit/Acclaim/Lebaron Sedan
1989 - 2003 (AB) Ram Van/Wagon
1989 - 1993 (AC) Dynasty/New Yorker/New Yorker Salon
1989 - 1993 (AD) Ram Truck
1989 - 1994 (AG) Daytona
1989 (AH) Lancer/Lebaron GTS
1989 - 1995 (AJ) Lebaron Coupe/Lebaron Convertible
1989 - 1990 (AK) Aries/Reliant
1989 - 1990 (AL) Horizon/Omni
1989 (AM) Diplomat/Gran Fury/New Yorker fifth Avenue
1989 - 2004 (AN) Dakota
1989 - 1994 (AP) Shadow/Sundance
1990 - 1991 (AQ) Maserati
1990 - 1993 (AY) Imperial/New Yorker Fifth Avenue
1994 - 2003 (BR/BE) Ram Truck
2004 - **2008** (CS) Pacifica
1998-2003 (DN) Durango
2002 - **2008** (DR/DH/D1) Ram Truck
2007 - **2008** (DC) Ram 3500 Cab Chassis
1995 - 2000 (FJ) Sebring/Avenger/Talon
1996 - 2000 (GS) Chrysler Voyager (International Market)
2004 - **2008** (HB) Durango
**2008 (HG) Aspen**
1995 - 2000 (JA) Cirrus/Stratus/Breeze
2007 - **2008** (JK) Wrangler
2001 - 2006 (JR) Sebring Sedan & Convertible/Stratus Sedan
2007 - **2008** (JS) Avenger/Sebring/Sebring Convertible
1996 - 2000 (JX) Sebring Convertible
**2007 - 2008 (KA) Nitro**
2002 - 2007 (KJ) Liberty
**2008 (KK) Liberty**
**2008 (L2) 300C (China)**
1993 - 2004 (LH) Concorde/Intrepid/Vision/LHS/New Yorker
/300M
2005 - **2008** (LX/LE) 300/Magnum/Charger
1996 - 2000 (NS) Town & Country/Caravan/Voyager
1995 - 2005 (PL) Neon
2002 - 2003 (PG) PT Cruiser (International Markets)
2001 - **2008** (PT) PT Cruiser
1997 - 2002 (PR) Prowler
2001 - 2007 (RG) Chrysler Voyager (International Markets)
2001 - 2007 (RS) Town & Country/Caravan/Voyager
**2008 (RT) Town & Country/Grand Caravan/Grand Voyager
(U.S. & International Markets)**
1997-2006 (TJ) Wrangler
2001 - 2004 (WG) Grand Cherokee (International Markets)
Vehicles equipped with Gas engines
1999 - 2004 (WJ) Grand Cherokee
2005 - **2008** (WK/WH) Grand Cherokee
2006 - **2008** (XK/XH) Commander
1989 - 1995 (YJ) Wrangler
**1989 - 2001 (XJ) Cherokee**
**1989 - 1993 (MJ) Comanche**
1996 - 1998 (ZG) Grand Cherokee (International Markets)
1994 - 1998 (ZJ) Grand Cherokee/Grand Wagoneer
NOTE :**AWA (Asian Warner) transmission are now included in this Service Bulletin. ATF+4(R) is recommended for AW-4 (Asian Warner) transmissions**
NOTE :This Service Bulletin DOES NOT apply to Sprinter transmissions, Crossfire transmissions, MK/PM vehicles equipped with Continuously Variable Transmission (CVT) and WG vehicles equipped with a diesel engine (sales code ENF) and a W5J400 or NAG1 transmission (sales code DGJ).
DISCUSSION:
ATF+4(R) - (Type 9602) is being used as factory fill for Chrysler Group automatic transmissions. ATF+4(R) is recommended for all vehicles equipped with Chrysler Group automatic transmissions EXCEPT FOR THOSE LISTED IN THE NOTE ABOVE.
NOTE :ATF+4(R) must always be used in vehicles that were originally filled with ATF+4(R). DO NOT USE ANY OTHER FLUID.
NOTE :ATF+4(R) is backward compatible with ATF+3, ATF+2, and ATF+. Additionally, ATF+4(R) can be used to top off vehicles that used ATF+3, ATF+2, or ATF+.
NOTE :If ATF+4® is used to service models originally filled with ATF+3, ATF+2, and ATF+ the fluid maintenance schedules listed for that model does not change. The service interval currently in effect for a given model should continue to be followed. Refer to the Service or Owners manual for maintenance schedule directions.
In general terms, If ATF+, ATF+2 or ATF+3 was the recommended fluid, it is now recommended to use ATF+4®
BENEFITS
^ Better anti-wear properties
^ Improved rust/corrosion prevention
^ Controls oxidation
^ Eliminates deposits
^ Controls friction
^ Retains anti-foaming properties
^ Superior properties for low temperature operation
FLUID COLOR
Mopar ATF+4(R) has exceptional durability. However, the red dye used in ATF+4(R) is not permanent; as the fluid ages it may become darker or appear brown in color. ATF+4(R) also has a unique odor that may change with age. With ATF+4(R) fluid, color and odor are no longer indicators of fluid condition and do not necessarily support a fluid change.
PARTS REQUIRED:
POLICY:
Information Only
Disclaimer :This bulletin is supplied as technical information only and is not an authorization for repair.
