quick trans questain
Old May 13, 2011 | 07:41 AM
logancounterman's Avatar
logancounterman
Default quick trans questain
ok i need a little help.
will a 360 trans out of a 1995 dodge ram bolt up to my 1990 318 v8.
i am talking to someone for a whole truck. so that might mean sas but i really just want the trans for my 318... will it work..
Old May 13, 2011 | 01:32 PM
9652dakota's Avatar
9652dakota
yes. it should work just fine the bolt pattern is the same and the blocks are even pretty much the same minus a few small changes.
why not use the 360?
Old May 13, 2011 | 01:48 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes I agree use the 5.9 and trans ect. Tons more power! The 3.9 V6 Magnums probably had as much power as the old 318's V8.
Old May 14, 2011 | 08:25 PM
logancounterman
yeah i would love to run that 360. but to run alover the place to do my lawncare and gas being 4.00$ a gallon. not thanks i may even run a 2 barral.... lol maybe...
Old May 14, 2011 | 09:33 PM
siggie30's Avatar
siggie30
To add: Yes, it is a direct swap, but you have to use your 318 torque converter unless the donor converter is neutral balance. 95' + changed the external weighting around the 360. Some had a weighted flywheel and some had a weighted converter depending on the year.
